Create a NetSuite Sales Order: Can't find 'FOR INVOICE GROUPING' field. Why?
urielp
I have a recipe that creates a Sales Order. However, I cannot find a standard field, called 'FOR INVOICE GROUPING'. Why?
Uriel
urielp
Hello, thanks. I manage with this: Finally it seems that this is a read only field, so I fixed that via a NetSuite workflow.
meghan-legaspi
Hey Uriel,
Can you please share more info around your recipe, like what apps you are integrating? A screenshot could also be extremely useful!
Thanks,
Meghan
ahanumantharaya
Hi Urelip,
Can you make sure that field is available in the role which you have defined in the Netsuite?
Or can you check what is the entity ID on "FOR INVOICE GROUPING" in Netsuite and try to find that field in the connector.
Sometimes entity ID will be different from the field name.
urielp
