โ04-22-2026 11:19 AM
Hello,
I'm working on a recipe in which I am pulling a list of customer outstanding invoices from a SQL table. I can get the data from the SQL and create a list, but I want to be able to loop through that list and create a table/list of invoices for each customer who have more than one outstanding invoice and send one email showing that table listing all of their overdue invoices rather than sending multiple emails for each overdue invoice. Would really appreciate some help with this.
โ04-22-2026 11:44 AM
If you have a list of all invoices, you can make a unique array of all customers. Then you want to loop on the array of customers first, and within that loop you want another loop for all of the invoices. You can then aggregate all customer-specific invoices by checking if the current customer value (outer loop) is the same as the invoice customer (inner loop). Once you have the customer-specific invoices aggregated in isolation from all invoices, you can process them however you'd like.
The "loop in a loop" may be frowned upon, but in this case you won't burn through a lot of tasks because your customer==customer conditional is narrowing down which invoices get processed. There are definitely other ways to do this that may have less task usage, but I think this approach keeps the recipe simple. Simplicity is a fair trade for a few extra tasks.
2 weeks ago
This is highly dependent on the schema of your 'Invoices' table, but it should be possible.
Select distinct customers with outstanding invoices from your DB. You now have a list of all unique customers that have outstanding invoices.
Loop through your customer list, and query SQL for all outstanding invoices associated with each customer.
Within each iteration of the loop you now have:
Create a Message Template to build a standardized HTML table for rendering within your email body. Parameterize the inputs to the template using Mustache. Use the 'Create Message' action of the Message Template connector to pass values from your SQL query to the parameterized template. Use the 'Document' datapill from the output of the message template action as input for your 'Send Email' action.
