Tuesday - last edited Tuesday
Hello Experts,
Can you help me to understand the difference between APIs and webhook triggers.
What kind of security cab be added if we use API and webhook as trigger.
Tuesday
Hi @ajay13chawda,
API - Its a collection of endpoints and 2way communication(can be also fire-and-forget).
Webhook - Its a single endpoint and only accepts request.
API - supports JSON WebToken, Oauth2
Webhook - None,Signature(https://docs.workato.com/developing-connectors/sdk/guides/building-triggers/securing-webhooks.html#s...
Thursday
Hi @ajay13chawda ,
Here is the simple explanation:
Feature / Aspect API (HTTP Connector/Workato API Platform) Webhook Trigger (Real-time trigger)
Definition | A method to expose endpoints which clients can call on demand | A mechanism where external apps send data to Workato via a webhook URL |
Triggering Mechanism | Pull-based โ Initiated by the client sending requests | Push-based โ Triggered by external systems when an event occurs |
Usage Scenario | Ideal for retrieving or sending data when requested | Ideal for real-time notifications from 3rd party systems |
Endpoint Exposure | API endpoints are published on the Workato API platform | Webhook URL is provided by Workato |
Rate Limiting / Throttling | Supported (on API platform) to prevent misuse or overload | Not directly supported, but can be managed via queueing strategies |
Webhook FAQ:
https://docs.workato.com/connectors/workato-webhooks/webhooks-faqs.html
Note: Webhook Triggers in Workato don't provide advanced security like OAuth or built-in HMAC validation.
API Security:
We have an option to use ๐ OAuth 2.0, Basic Auth, API Key, Custom Headers.
API Security: https://docs.workato.com/api-mgmt/securing-apis.html#api-clients-and-access-profiles
Shivakumara K A
