2 weeks ago
I have built an integration comprised of multiple recipes, properties, and lookup tables in a team hosted in the Europe environment. I need to port the integration (recipes, properties, and lookup tables) to a different team in the Europe environment and to a different team in the North American environment.
Workato doesn't allow cloning (or copying & pasting) recipes across teams or environments. Is there a way to speed up or automate the porting process besides manually porting the integration?
2 weeks ago
Hi Edgar, do you have Recipe Lifecycle Management available in your workspace? You can find it under the Tools menu. If you do, you can use Recipe Lifecycle Management to export a package that includes all the necessary assets (recipes, connections, lookup tables) from the source Workspace in the EU datacenter. Then, you can import the same package into the destination Workspace (EU or US datacenter) using the Recipe Lifecycle Management tool.
2 weeks ago
2 weeks ago
@javier-riesco @edgar_elias add on to the provided solution, make sure that re-connect the application connection as currently Workato not support establishment of connection one's we deploy/import packages to another workspace or to higher environment. Hope these points helps.
Connector Sharing:
When migrating between teams/environments, ensure:
