3 weeks ago
I am trying to map the JSON of a list to a string to pass to another application. When using the mapper I can't select the entire list. I want this one parameter to be the entire JSON and the other application will parse it.
Is there something simple I am missing?
3 weeks ago
I figured this out. You have to go into formula mode and then you can include the JSON content. Leaving this here in case it helps someone else.
3 weeks ago
