Do not break foreach loop when API fails
bhavesh-patel
Issue is inside custom connector ruby code.
Context: I have a list of companies in an array then I am using .each method to loop every company and then hitting an api call on every company.
Problem: Now one api call is failed for a company and code breaks. I don't want code to break, instead I want loop to continue as we use try catch in many languages to prevent breaking of loop. How to acheive the same in Custom Connector SDK using ruby.
2 ACCEPTED SOLUTIONS
Ruby exception handling is unfortunately also not supported in the SDK-Code.
There is no support for exception handling so I have move this code on the recipe level and then I used repeat action in a parent recipe on my company array and then every action goes to a child recipe where I use monitor block of recipe to handle exception from API. Then I move every error into lookup table.
bhavesh-patel
My API call is as below:
company_ids.each {
                    |company_id|
                    puts("company_id: #{company_id}")
                    companyobject = post("#{base_url}/api/v2/labor-model/location/#{company_id}/run").payload(start:start_unix, end:end_unix).headers("Authorization": auth_header).
                    after_error_response(400, 401, 404, 417, 500) do |code, body, header, message|
                        error("#{message}: #{body}")
                    end
                    puts("companyobject: #{companyobject}")
Hey @bhavesh-patel,
I think this page on ruby loops could be helpful for you: https://www.tutorialspoint.com/ruby/ruby_loops.htm
You can also find more variations of 'each' here: https://docs.workato.com/developing-connectors/sdk/sdk-reference/ruby_methods.html#each
Please let me know if you find your solution within those pages!
Cheers,
Meghan
I'm not sure if begin/rescue or catch/throw are supported in a custom connector, but you should give them a try. They aren't supported in the Ruby recipe connector (I tried and confirmed with Workato support) but the connector SDK tends to have broader Ruby support.
https://www.geeksforgeeks.org/ruby-exception-handling/
Here's an example:
companies.each { | company |
   x = {}
   begin
      x.split(';') # example that will throw error
      # put your API call here
   rescue
      puts "error is skipped"
   end
