โ07-09-2025 03:34 PM
Has anyone had success using a dynamic hash key? Use case is I have a lookup table that has 2 columns that are just Keys and I have 2 objects (one from JIRA one from Salesforce) and I want to loop through each lookup table and do a comparison to determine if the values changed. pseudocode version:
sf = {'field1': '123'}
jira = {'field_1__c': '123' }
lookuptable = [{'jira': 'field1', 'sf': 'field_1__c' }]
for fieldLookup in lookuptable:
if jira[fieldLookup['jira']] != sf[fieldLookup['sf']:
isChanged=TrueMy attempts using jiraFieldsPill[jiraLookupPill] and jiraFieldsPill["jiraLookupPill"] keep just giving me generic 'Recipe Error'
โ07-09-2025 09:34 PM
Hello @kylevarga ,
The error you're seeing is likely due to a key mismatch between your lookup table and the actual jira object.
In your example, youโve defined the jira object like this:
jira = {'field_1__c': '123' }But in your loop, you're doing:
And your lookup table contains:
lookuptable = [{'jira': 'field1', 'sf': 'field_1__c' }]So basically, your code is trying to access jira['field1'], but that key doesnโt exist in the JIRA object โ it only has field_1__c Thatโs why youโre getting an error.
Also, just a quick note โ field_1__c looks like a Salesforce custom field (since __c is usually used for those), so it probably belongs to Salesforce, not JIRA.
Hope I got your question right โ let me know if I misunderstood anything!
