Error: The provided next page token is invalid or expired
antonyfm
I'm facing an issue when I run triggers that generate a CSV as output.
When I run the recipe, it throws the error that the Next Page Token is invalid or expired. Interestingly, the same recipe used to work earlier.
I'm finding this issue when I use triggers like: Export new/updated issues in Jira which generates output as a CSV file.
I'm not able to use Logger or CSV tools to figure out if there is any issue causing this.
Has anyone run into a similar problem, please let me know.
Obugari
The issue you're facing is related to pagination,  we canโ€™t apply pagination directly inside a trigger step. As a workaround, if itโ€™s okay for your use case, you can use a scheduler to run the recipe at shorter intervals. Then, inside the recipe:
  • Use a "while loop" to handle pagination.
  • In the first loop, create a list to store results.
  • Make a Jira call (or HTTP call).
  • On the next loop, call Jira again using the Next Page Token and add the results to the same list created earlier.
  • Use the loop condition as โ€œNext Page Token is presentโ€ โ€” so it keeps looping until thereโ€™s no token left.
For reference, Iโ€™ve attached a screenshot showing this setup. I used an HTTP call, but in your case, you can use the Jira action instead.pagination2.png
Thankyou
Himaja
Hi @antonyfm,
  • Restart the Recipe: Stop the recipe and restart it to reset the token.
  • Use Timestamp Pagination: If available, switch to timestamp-based pagination, update_at
  • Reduce Trigger Interval: Run the trigger more frequently (e.g., every 5โ€“10 mins) to avoid token expiry.
  • Check CSV Output: Add a logger before the CSV step to inspect data. Try building CSV manually using Search + Repeat.
  • Disable Pagination (if possible): For small datasets, test without pagination.
