Wednesday
I am using Event Streams for an integration. Has been running without issue for several years now, but about an hour ago I started getting timeout issues attempting to push data into the event stream and reading the event stream.
Has anyone run into this issue before and if so, how was it resolved
This is the error message:
Error checking for new jobs
Timeout
Summary: Failed to complete the action within the timeout
Detail:
Error ID: 2ecc70ed-84eb-4eb6-8a5e-ed8814cef4e1
Wednesday
Wednesday
I'm having the same issue right now. Seems transient, and it isn't happening on all event streams and all tenants. Last successful job took 30 seconds to write to the event stream. I figured it's a minor outage that will resolve quickly.
Wednesday
Here's hoping it's a workato issue. I have a recipe that processes a lot of data into an event stream and it's locked up right now and throwing timeout errors like crazy, but as you are observing my other recipe that uses a different event topic is just fine
Wednesday
I just got the text that the issue is resolved.
Wednesday
Thanks! It appears my error messages have stopped too! Now to re-run all the jobs that failed
