Example how to parse a JSON file and use where and pluck to extract specific data
gfranco
I am following along on the training in Automation Pro III, I completed the part of the CSV file and at the end, you can logger the data in the Workato app.
I want to follow the same scenario but using a JSON provided, but I do not have an idea after configuring the JSON document what else I should do.
1. Trigger scheduler
2. Parse Json document
use where('country': "FRANCE).pluck('email')
3. Log message to job report
I appreciate your help.
Hi @gfranco ,
Hereโ€™s my understanding based on the given requirements for the main logic:
  1. Parse the JSON data and filter it based on the Country field, then log the filtered data.
Solution:
  1. Pass the required data as-is in the Parse JSON step (both sample and actual documents).
  2. Use a Formula to extract the filtered data (e.g., where('country': "FRANCE").pluck('email')).
     Double quote should there for [Example: "Country",  "FRANCE", "email"]
Parse JSON: This component is used to extract incoming data based on the provided sample document.
Thus, it's best to apply the Formula after the extraction step 2 in your case.
Shivakumara K A
