SFTP connectivity using while using SSH
sravanij
Hi All,
I am trying to connect to a SFTP server using public/private key authentication.
The public key is configured in the SFTP server and when I am trying to establish connectivity using Workato with private key, getting below error.
"could not settle on encryption_client algorithm Server encryption_client preferences: aes256-gcm@openssh.com,aes128-gcm@openssh.com Client encryption_client preferences: aes256-ctr,aes192-ctr,aes128-ctr,aes256-cbc,aes192-cbc,aes128-cbc,rijndael-cbc@lysato"
My private key as below info:
Proc-Type: 4,ENCRYPTED
DEK-Info: DES-EDE3-CBC,49F1D315CD34905A
Can you please help me to know what exactly is the issue.
Sravani
Hi @sravanij,
Based on the error, here is my understanding and suggested fix:
1. Your server supports:
aes256-gcm@openssh.com, aes128-gcm@openssh.com
2. Your client supports:
aes256-ctr, aes192-ctr, aes128-ctr, aes256-cbc, aes192-cbc, aes128-cbc, rijndael-cbc@lysato
Fix: Update your SFTP client to support aes256-gcm@openssh.com or aes128-gcm@openssh.com, OR modify the server configuration to allow aes256-ctr
Kindly try from your end and let me know if you need further help.
Shivakumar K A
