a week ago
I have a recipe where I am pulling invoices from the past 2 years. I want to add a condition where it will only pull records for 10 customers. I have not been very successful in setting up a formula using customer ID's. I have attached a copy of the condition I have currently. Any help is greatly appreciated. Thanks!
a week ago
It's very possible that the other conditions are conflicting with the ID condition, but I won't be able to tell without seeing all of them. You should test the query with only a single condition first to ensure it's working, and then build on additional conditions to ensure it keeps working.
With a single condition, try these steps:
a week ago
Thanks Gary for the response!
So my recipe works when I use one customer ID. However, I want to retrieve data from 10 customers. Do I just enter multiple customer ids and use "," to separate each? Like: 2112, 1234, 456, and so forth? That's where I am struggling.
a week ago - last edited a week ago
I'm not familiar with the platform and its API so I can't say for sure. Is this Epicor or some middleware?
It might take an array like:
[123, 456, 789]
Or a string:
"123, 456, 789"
Or maybe it has built in operators:
"123 OR 456 OR 789"
Another option would be to query each ID individually and combine them into a single array once you have all the results. It's not very efficient, but it will definitely work based on your testing so far.
a week ago
I will try these options with a fresh mind on Monday. Thank you once again for your help!
