Get the error details from a file.
sadiya-sultana
How to get a particular line of message from a text file.
max-knutsson
So you are trying to search a file content for specific error message? like a text .log file or .csv?
sadiya-sultana
it's saved as xyz.txt
about 3000 lines
ajorde
You could split the csv file contents by new line character and then pull the line that you want - if you're searching for certain messages, you can potentially do a gsub on the contents and use a regular expression to find the matching lines. I think we'd need to know more about the scenario though in order to help further.
bcastro
You can use https://regex101.com/library to create your regex
