Get value from list with multiple nested objects, based on a where formula
mlamotte
We have a Parse EDI task, of which the output we put in a list.
For a specific field, we need to pluck a value, based on a qualifier in an object.
The list "MOA loop" contains multiple "MOA" objects, each with an object "MonetaryAmount", which in itself contains 2 variables.
Based on the value of the first variable, we want to select the value of the 2nd variable.
Example below:
{                  MOA loop:
                      MOA:
                        MONETARYAMOUNT 01:
                          Monetaryamounttypequalifier 01: 176,
                          Monetaryamount 02: 2588.16
                      MOA:
                        MONETARYAMOUNT 01:
                          Monetaryamounttypequalifier 01: 86,
                          Monetaryamount 02: 15528.98
                      MOA:
                        MONETARYAMOUNT 01:
                          Monetaryamounttypequalifier 01: 79,
                          Monetaryamount 02: 12940.82
                      MOA:
                        MONETARYAMOUNT 01:
                          Monetaryamounttypequalifier 01: 125,
From this list, we want to get the Monetaryamount 02 where the Montaryamounttypequalifier 01 = "125".
Can someone help with this?
Thanks in advance!
Solved:
MOA.where('MOA.MONETARYAMOUNT_01.Monetaryamounttypequalifier_01':"86").pluck(['MOA','MONETARYAMOUNT_01','Monetaryamount_02']).first
Community_JSON.jpgHi @mlamotte
MOA
.pluck("MONETARYAMOUNT_01").where(Monetaryamounttypequalifier_01: "125")
i.e. MOA is a Object
Make it more dynamic by using .where condition after .pluck operation.
Shivakumara Avadhani
MOA
Thanks, even better solution!
