โ09-25-2023 01:17 PM
Hello, has anyone tried to connect to the Azure File Share instead of Blob Container?
Does this have to go through a HTTP Connector? Thank you.
โ10-04-2023 05:03 AM
Hi @sher-yim806 ,
If you want to use Azure Files Share API, you can use our Universal Connectors like HTTP or SDK.
Hi @sher-yim806 ,
