How do i perform a formula on a list input?
jarh15
I am trying to see if a list is present and if it's not, then use another list. I'm using this in a list input step for a modal. I would use a formula but there is no button for formula mode on list input.  See screenshots
1dheeraj2
Hi @jarh15
As far as i know, list input fields don't support formula mode functionality.
Since you're querying the same sheet with different values, I assume you're working with consistent column structures.
I would use below two approach ( if columns are same )
  1. Using Collections:
  • Collections support formula mode
  • You can check for data existence using expressions
  • Query data from collection. Use Query output in your slack action.
  • Drawback: Requires 2 additional tasks in your flow
    2. Python Connector Approach:
  • Create a custom Python script to handle the logic.
  • Performs all necessary checks internally
  • Returns a consolidated output list
  • Drawback: Requires basic Python knowledge
Please share if you discover an even better solution, as this is a common scenario many of us encounter.
1dheeraj2
Hi @jarh15
