How to convert a text in a Datapill
tco
Hello the Community,
Happy Holidays !
Maybe a simple question but I am stuck...
I have the following response from one of my step of my recipe :
"{"text-Platinum","choices":[{"text":"\n\n1. MED001 - Digital Stethoscope - $99.99\n2. MED002 - Blood Pressure Monitor - $59.99\n3. MED003 - Disposable Surgical Caps - $9.99","index":0,"logprobs":null}}
What will you recommend to extract the following :
ParNum : MED001, MED002, MED003
Description : Digital Stethoscope, Blood Pressure Monitor, Disposable Surgical Caps
Price : $99.99, $99.99,$9.99
and be able to have it in a DataPill I can use in the following steps of my recipe.
Thanks in advance for your help,
Happy New year,
Thierry
dcornwell
Hi Thierry,
Using my new best friend (ChatGPT) it came up with a RegEx "\bMED\w+"
which can extract the values starting with MED from the text.  Having not used RegEx in Workato I had a quick try by following the Workato  documentation and it didn't work.
I'm out of time to experiment today but the other approach I would take with that particular text is to parse it as JSON (or just deal with it as a string) and split it using the newline (\n), then iterate over it and look for the location of ".M" then use that to get a substring of the MED value.  Obviously there's some nuance in how to do that but that's a general approach.
Having said that, the best bet might be to get someone who knows RegEx to advise how to implement it in Workato using that expression "\bMED\w+".
Regards, David
dcornwell
Hi Thierry,
Regards, David
arturgm
Just to add 2 cents, this is also great for fiddling around with regex: https://regexr.com/
meghan-legaspi
Community Manager
Community Manager
Hey @tco! Did either of the suggestions provided work for you? Would love to get an update if you have one!
