04-03-2025 02:16 PM
Hi all,
My process is that I have a list of data, I extract the relevant data from the list, add the data to the payload, and then POST that data to a particular endpoint. The key consideration is that when a key-value pair has a null value, that key-value pair should be omitted from the payload. Every system I have seen has a consideration for this, but what I understood to be the solution here is not working. I employed the "SKIP" function in an "If value is present, pass value, if not then SKIP" logic (Figure 1). That said, when the value is not present, the key-value pair is still being included with "null" (Figure 2).
My impression is that this should not be happening. I have had to create separate outbound schemas for every potential combination of fields that are null vs populated, which is insane. What other methods can I employ to achieve the same goal?
Figure 1
Figure 2
Note 1: I am using the Dayforce SDK
Note 2: I have already attempted to use a common data model schema and the the .COMPACT function, however it had unintended consequences for integers in the payload that has made it untenable as a solution.
#compact #skip #automation #Dayforce
04-03-2025 09:07 PM
Skip is just another way of providing nil, but it doesn't remove the key.
Only compact removes the key, but the problem with compact is it's not recursive.
If you use compact on an array, it's only going to remove nil items from the array. It's not going to skim through the contents of each item in the array and remove keys with nil values.
My preferred way of solving this is with a Ruby action. Add your array or object as the input, and clean it up using the below code. The "data" object is an example of an array of objects with various null keys to purge.
data = [
{"one": "a", "two": "b", "three": null},
{"one": "a", "two": null, "three": null},
{"one": null, "two": "b", "three": null},
{"one": null, "two": [1,2,3], "three": {"four": "hello", "five": null}}
def deep_compact(obj)
case obj
when Hash
obj.transform_values { |v| deep_compact(v) }.compact
when Array
obj.map { |v| deep_compact(v) }
else
obj
end
end
cleaned_data = deep_compact(data)
cleaned_data: cleaned_data
}The end result:
"output": {
"cleaned_data": [
"one": "a",
"two": "b"
"one": "a"
"two": "b"
"two": [
1,
2,
"three": {
"four": "hello"
"log": ""
08-18-2025 11:35 AM
If you are interested in a no-code solution to omitting nested null key-value pairs from a JSON payload, please add signal to the below ideas:
https://ideas.workato.com/app/#/case/415544?cpid=931134c4-fa0c-41ba-815c-c31e90cf9eaa
https://ideas.workato.com/app/#/case/504059?cpid=23919909-12f4-4112-8d25-efba83464960
FYI the only solution our consultant team has found that has worked is the Deep Compact Ruby formula that Gary shared, and a JavaScript code snippet that one of my teammates wrote. There needs to be a better solution here!
To access the ideas, you may need to log out of Workato, go to this link https://docs.workato.com/en/contact-us.html#for-requesting-enhancements:~:text=US%20Data%20Center,op... then log in again! Weird process but it worked for me
08-18-2025 11:49 AM
Thanks for sharing. I voted for it.
While I'm here...
This may have zero relevance for you, but would you mind voting on this request for me? It has languished in the queue for a couple years and it would be a huge improvement for the work I do.
08-19-2025 01:30 PM
Done, and while we're here, what about this one. The recipe diff always flags every Recipe Function call I make, which makes the diff cumbersome and less useful. Does it do that for anyone else? It says I'm the only one who wants it, but... I wonder...
