02-17-2026 10:06 AM - edited 02-17-2026 10:13 AM
I have a list of Ids in a variable:
{ObjectTypes:[6,118,119]}
want to have this injected into a JSON parameter for a JIRA API call
"qlQuery": "objectTypeId IN ()"
I tried using the variable between the () and it did not like the formula.
The resulting JSON should be:
"qlQuery": "objectTypeId IN (6,118,119)"
I could hard code this, but it is always better to be data driven.
02-17-2026 08:32 PM - edited 02-17-2026 08:32 PM
You're not supposed to copy the exact text I sent you.
Where I write:
"qlQuery": "objectTypeId IN (#{[ObjectTypes data pill].join(',')})"
}You need to replace "[ObjectTypes data pill]" with the actual data pill from the previous step of your recipe. A "data pill" is the UI element that you drag/click into the input field.
