Discover: Enhancements to the existing Accelerators (February 2024)
manoj-gaddam
Our customers' input was instrumental in the updates made to several accelerators. Check out the changes below:
EDH V3.3:
Enhancements:
   Bulk Upsert
  • Recipe Funcation added with SQLs to perform bulk upsert in SQL Server Database
  • JS Validation Function created to generate case statements support by SQL Server
   Fuzzy Matching
  • Fuzzy matching action is added to the DataHub connector.
  • API Endpoint created to accept the request from Connector action.
  • Snowflake JARO Wrinkler Function was added in Customisations as an example to extend the fuzzy matching logic.
   Data Guardian
  • Workflow App created for Approving the request.
  • Data Stewardship Data table is added to the Data Hub solution to save Data Gaurdian Requests.
  • Recipe added for managing of Data Gaurdian requests
OPA Manager V3.0:
New features:
  • Create, Update, Delete and sSearch OPG Operations from UI
  • Create, Update, Delete and sSearch OPA Operations from UI
Changes:
  • Removed accessing config files from On-Prem command line scripts and commands will be provided in the connection itself
  • Updated to access version of OPAs
CICD V3.3:
New features:
  • Project Property Migration.
  • New Category in User Roles for restricting Production Deployments.
  • AUDC Server Supported for Connecting to the Workato Platform.
  • Test Automation Results Displayed to Slack & MS Teams UI.
Changes:
  • New Droplist in Slack & MS Teams UI to select the Property Type (Environment & Project).
  • Assign Deployment Reviews to Individual, or to Everyone in a Group or Channel.
SOAR V2.1:
New features:
  • Efficient Integration of User Comments from Slack to Interact with AI Security Co-Pilot.
  • Seamless Communication with AI Security Co-Pilot for Detailed Insights, Recommendations, and Additional Functionality.
  • AI-Generated Explanations for Each Recommendation.
Changes:
  • Enhanced User Interface (UI) for Slack.
  • Enhanced Calibration of Prompt sent to Gen AI Platform for the AI Security Co-Pilot.
AQS V3.2
New features:
  • Task Optimisation Assessment: Added a Recipe to download Task Optimisation Assessment Results.
Changes:
  • Custom Rules: Modified Custom Rules Recipes for improved alignment with custom rule specifications.
  • Improvements: Variable total_count in List Quality Assessment Executions recipes for Slack & MSTeams, migrated from configuration parameter to project property for streamlined configuration management.
Knowledge Workbot V2.0
New features:
  • Interactions: Making Workbot fully Conversational
  • Access Control: Application specific access control for Workbot users
Workato Reporting Embedded V1.1.1
New features:
  • Alert for error percentage
  • CSV Report update to add summary fields
Changes
  • Fixed HTML report for month format to align with 0-11 format for Google Charts
Would you like to see a demo for any of the accelerators? Get in touch with us through accelerators.feedback@workato.com
0 REPLIES 0
