UID creation via Workato (automatization of creation UID)
Sultanbek
We have a use case where we need to import revenue transactions from Intacct to Anaplan via Workato using Unique ID for each transaction. Could you please suggest me how can  Workato create an Unique ID (UID) to each new transaction for import?
2 ACCEPTED SOLUTIONS
The Sheets API has an endpoint for this. It's not supported by the Workato connector, but you should be able to use the custom action to call the endpoint and make the update.
Sultanbek
If someone has the same question regarding creation of UID in workato there is useful formula called "workato.uuid" or you can create your own by using the "encode_base64" formula.
Star Chef I
Star Chef I
I don't know of a native way to do it in Workato, but you can use an HTTP action to call this API and generate one for free.
https://www.uuidgenerator.net/
For example, just call https://www.uuidgenerator.net/api/version4/500 and you get 500 freshly generated UUIDs
@gary1 Thank you for your advice! I wonder if we can create an action of adding new columns in google sheet for example? Do you have any insights?
Many thanks! I will try
