โ01-30-2026 02:00 AM
Hi, having bit of trouble with a data time variable, my datapill is in this format: 2026-01-29T06:01:28.000000-05:00 and using all possible hints from AI to convert it to YYYY-MM-DD HH:MM but it just returns: Error calculating input for field 'date':
wrong number of arguments (given 1
expected 0)
I'm only just starting my journey with workato
โ01-30-2026 03:40 AM
Hi @Sonia,
Yes, I too getting errors with strftime and .to_date and .to_time formula, but we need to walk through some work around solution with formula. but for instant thought, please check the below solutions.
Hi @Sonia,
โ01-30-2026 08:27 AM
Hi @Sonia , this is the correct solution formula:
="2026-01-29T06:01:28.000000-05:00".to_time.strftime("%Y-%m-%d %H:%M")
where "2026-01-29T06:01:28.000000-05:00" is the value of field datapill
โ01-30-2026 08:51 AM
This is the way.
โ02-02-2026 06:21 AM
Hi @Sonia ,
Thanks and regards,
