JavaScript Connector handling null values
jharrison
Has anyone had luck handling null values in a JavaScript Connector? I have tried all these below but the error remains "Cannot read properties of null (reading 'regulation')"
regulation = arrayValue.regulation
regulation = arrayValue.regulation || 0
regulation = arrayValue[0].regulation || 0
if(arrayValue.regulation === null){regulation = "null"} else {regulation = arrayValue.regulation}
if(arrayValue.regulation != null){regulation = arrayValue.regulation} else {regulation = "null"}
Found it! The JSON had spacing that was different than the sample file I was using. I realized that all these attempts at finding the correct path to the key were where I needed to focus. So I went back and looked more closely at the parse JSON Output and noticed the spaces in the Output that I had not placed in the sample document of JSON parse, which is why it kept resulting in 'undefined'. Added the spacing and it worked.
Thanks for your help
Jim
12 REPLIES 12
Star Chef I
Star Chef I
Is this an accurate representation of input_json? Not sure if Status is an object or an array.
"FirstName": "Spider",
"LastName": "Man",
"EmployeeId": "123",
"Status": {
"Regulation": null
Yes, minus a couple square brackets [].
"LastName": "",
"FirstName": "",
"Message": null,
"Status": [
"Regulation": ""
maryhodges
