Lookup Table add entry if doesn't exist
deepaks
Is there way to add entry to lookup table only if doesn't already exist (based on a specific column value?)
Came across a recipe which  seems to be inefficient - it's looking a search for the value in lookup table, monitoring for error (entry not found error) and then adding/inserting.
This should be possible. If you're receiving an error when the value is missing, you can use an error handler action to create the lookup table entry and then retry the action.
deepaks
That's exactly what is done, but I hoping for better way - for now what you described works. Thanks!!
Just curious, what would you consider a better way?
mppowe
Maybe if it had an Upsert action?
