Lookup Table search entries. Use formula Mode
bcastro
Hello Automation Pros,
I've created a lookup table with column timestamp (assigning now()).
However I would like to retrieve all entries with a specific date, let's say today(DD-MM/YYYY) and not the entire timestamp.
I've try using lookup("Employee Failed Audit Lookup Table - DEV","Timestamp":)
but I don't seem to know how to truncate timestamp/change format in the column itself.
I don't want to create a separate column just for storing the current date due to the 10 column lookup table restrictions and endup with 2 columns. one for timestamp and another just for date.
If I search directly in the Lookup table just providing the date it works but not when using search entries.
Thanks in advanced
susrith-kalluri
Try using this formula
lookup("Employee Failed Audit Lookup Table - DEV","Timestamp":(datapill.strftime("%m/%d/%Y")))[Column_name]
Syntax:lookup("TABLE_NAME", "REFERENCE_COLUMN": datapill)["LOOKUP_COLUMN"]
bcastro
thank you all for your responses!! . I actually opened a ticket service with Workato regarding the lookup function. I am passing datapill.strftime("%m/%d/%Y") but it is not filtering the values and instead returning all entries. For now as suggested I am storing the timestamp without timezone and pulling all records and then storing them on a collection and doing SQL.
