Monday.com connector
Ilan
hi all
i have a valid token but cant establish a connection without "column values" which i cannot figured.
is someone familiar with the Monday connector?
advanced thanks
Hi @Ilan,
This action: "Get Item by column values" is supposed to return items from a certain board, that have a specified value. Like a search operation.
In that field "Column value" you have enter (or use a data-pill) the search term you would like to search for.
Cheers,
Chris
Hi @Ilan
Assuming, you have a column in your Monday.com board, that contains a certain status (e.g. Done, Open, In progress, etc.).
Now, depending on your use-case, you set the Workato Action Column-Value to the status (e.g. "Open") you want to search items for.
Cheers,
Chris
6 REPLIES 6
chris-wiechmann
Hi @Ilan
Can you please explain in more detail, what do you mean, that you can't establish a connection without "Column values", as at the connection time, the columns shouldn't matter?
Thanks,
Chris
Chris, thank you for reaching out.
in the connector dialog b
ox i have three mandatory fields
1. Board ID
2.Column ID
3. Column value
I allready have 1 and 2 , but icant finf 3.Column value
Hi @Ilan,
Cheers,
Chris
do you have an example of a data pill or search term?
can i use a wildcard?
