Monday.com connector
Ilan
hi all
i have a valid token but cant establish a connection without "column values" which i cannot figured.
is someone familiar with the Monday connector?
advanced thanks
2 ACCEPTED SOLUTIONS
Hi @Ilan,
This action: "Get Item by column values" is supposed to return items from a certain board, that have a specified value. Like a search operation.
In that field "Column value" you have enter (or use a data-pill) the search term you would like to search for.
Cheers,
Chris
Hi @Ilan
Assuming, you have a column in your Monday.com board, that contains a certain status (e.g. Done, Open, In progress, etc.).
Now, depending on your use-case, you set the Workato Action Column-Value to the status (e.g. "Open") you want to search items for.
Cheers,
Chris
thomas
HI Ilan,
I found the API docs for this value: https://developer.monday.com/api-reference/docs/column-values-v2.  Under Implementation, they include an example.  Does this help?
Best
Hi @Ilan
Cheers,
Chris
