Need to get custom array from custom connector to a recipe step
bhavesh-patel
I have created a recipe. On step 2 I have used custom connector which get some api and perform some logic to create a custom array for me which I have declared inside the code.
Now I am unable to send this array as an output so I can use it on step 3 of recipe as an input. I want to use repeat action step to do some other stuff on this array.
How to achieve this?
I have tried the below thing as per document, but I guess it worked when the response is directly came from API and not for custom array created by me inside code:
output_fields: lambda do
              label: "Person's Height List",
              type: "array",
              of: "string"
        end
Example of arrays: =>
height_array ["172", "167", "96", "202", "150", "178", "165", "97", "183", "182"]
comapny_id_array [1, 2, 3, 4 , 5, 10]
2 ACCEPTED SOLUTIONS
I checked one of my connectors and you're configuring the output field correctly. The issue may be related to how you're constructing the custom array, or how you're passing the custom array to your output.
Here's how I managed it:
Output field:
   "type": "array",
   "of": "string",
   "label": "List of Asset IDs to Download",
   "name": "list_of_asset_ids_to_download"
Sample API Output:
{"asset_items": [
   {"id": 1},
   {"id": 2},
   {"id": 3}
Execute:
# API call
response = get("/api/v1/search?query=blahblahblah")
# create custom array and add it to response as a new key
response[:list_of_asset_ids_to_download] = response['asset_items'].pluck('id')
Now I can access "list_of_asset_ids_to_download" as an array of strings data pill on the connector output, like this:
list_of_asset_ids_to_download:
      8005903,
      8005899,
      8005896
Hope this helps!
Thanks for helping me here.
What worked for me is to add my response into a new hash with the same key as given in output field name. In my example - height_array. Then it automatically picked up the array and gave it to output of the step.
My code for reference:
execute: lambda do |connection, input|
  # API Call from star wars free API
  all_people = get("https://swapi.dev/api/people")
  all_height_array = {
    "height_array" => all_people['results'].pluck('height')
end,
      label: "Height Array",
      type: "array",
      of: "string"
end
Output field:
   "type": "array",
   "of": "string",
Sample API Output:
{"asset_items": [
   {"id": 1},
   {"id": 2},
   {"id": 3}
Execute:
# API call
      8005903,
      8005899,
      8005896
Hope this helps!
end,
      type: "array",
      of: "string"
end
