yesterday
yesterday - last edited yesterday
Within the loop branch action, I can only see Index, Size, Is first and Is last data pills
The Foreach output looks like this in the job history:
Index: 0,
Is first: true,
Is last: false,
Item:
value: CN=o365_Office365_E5,OU=Office 365 Licensing,OU=Groups,OU=Common,OU=Enterprise,OU=xxx,DC=xxx,DC=xxx
yesterday
What are you using as you input list when defining the For Each Repeat? Because when I use a data pill that is a list object, I can see this when I am trying to select an item from the current data item in the loop. Step 22 represents the For Each Loop and those are all the data pills from inside that item I can select
