Salesforce Internal ID
nvinay091
Iam trying to send Data from SQL to SalesForce sandbox
There is a mandatory field "Salesforce Internal ID"
Object in SF is " Revenue Data"
What is this Internal ID and where can I get this from
!!!! There is no Id column in SF !!!!
4 REPLIES 4
a-muthiah
Classification: Confidential
If your action will result in an update (rather than insert) in Salesforce , then you need to first get the Salesforce object and use that internal ID
If your action will result in an insert or create , there is no need to provide  internal ID
Thanks,
Muthiah
nvinay091
What is that Internal id that you are referring, Bcz I don't have any column in SF or SQL as internal id ,
Where should I check that for
max-knutsson
Hi Narayana, could you paste a screenshot please (remove any customer data so its not visible)? So we can see which action/where to check ourselves and help you. Otherwise the internal id is just the ID in salesforce, usually only neded if you update
mroldanvega
When you use Workato to Search the object in Salesforce, the data pill for the internal id is called 'Record Id'. Do you have a data pill called Record Id?
