3 weeks ago
Team,
I am trying to use http connector in workato, and looking for sample request with POST and body in it. Please share the sample if you have any.
Inderjeet
2 weeks ago - last edited 2 weeks ago
You can construct the POST body however you need to, so long as it's a valid JSON.
If you want to parse the response of the request, this is also possible.
Here's what I usually do to set it up:
1. Set up the request above and test the recipe.
2. Go to the test job and look at the output of the request. Click "Copy Raw JSON"
3. Go back to the HTTP action in the recipe editor, and in Response > Response Schema, click "Use JSON"
4. In the JSON editor, paste the raw JSON you copied in step 2.
5. Delete everything except the "response" object (keep what is highlighted below)
Like this:
6. Click Next and then Generate, and this will create a schema of output data pills based on the JSON
7. You can now access the data pills in subsequent steps in the recipe
3 weeks ago
Here you go:
3 weeks ago
Thanks for your reply. Is it possible to parse the json in the body?
Like this:
