Scheduler Wait action doesn't resume
Karsten
Hi there,
I've built a very simple recipe that should wait for 10 seconds and then resume and complete. But it never passes the wait action.
I'm in GMT+1 timezone and the resume timezone is converted PST but it is the correct time.
Am I using it wrong?
Thanks,
11 REPLIES 11
Hi @Karsten,
Try using one of the solutions below to ensure the recipe behaves as expected. With or Without formula mode, recipe should work.
Attaching the response for your reference. Please let me know if you need any further assistance or clarification. Make sure to start the recipe and test it properly, rather than testing directly from the recipe.
Shivakumar K A
Text mode:
Hi @Karsten,
Could you try Starting the Recipe and see the functionality.
When I tried with test recipe, recipe was never passing the wait action.
Also I noticed a small delay of 0.5 sec to whatever time I have specified
Example if 60 seconds, it got resumed at 1 min .5 sec
Hi @Prudvi,
We need to start the recipe and allow it to pick up the job. Make sure to set the timing using formula mode or text and apply the correct configuration before testing. The solution for this has already been shared.
Shivakumar
Hi @shivakumara,
It seemed to work even without formula mode.
