SurveyMonkey Document Download
dan-lowry
I am working on a SurveyMonkey integration that is looking to download any documents (typically PDFs) that are loaded into response answers. I'm able to extract a"download_URL" value using "https://api.surveymonkey.net/v3/surveys/{Survey ID Datapill}/responses/{Respondent ID}/details?simple=true".
The document download URL retrieved is NOT an API endpoint, but rather can be navigated to for a direct automatic download (provided a user session is active).
When testing this using the "Get Files from URL" utility connector, the step does not error, but when I try and use the file contents to upload to another platform, I recieve an error that should not occur if the file was downloaded correctly initially.
"Get Files from URL" says it requires a publicly-accessible URL, but has anyone ever used it to extract a file from a platform you were previously authenticated for within that recipe? If not, any recommendations on how to download a file from an authenticated app that does not provide an API GET endpoint for that file.
james-ng
When the File Content is downloaded, you cannot use the [File Content] datapill directly to upload to another platform.
You should use [File Content].encode_base64 in formula mode.
More details in documentation: https://docs.workato.com/features/handling-binary-files.html#base64-encoding
