โ02-10-2022 10:02 AM
Hi Team ,
This is an urgent requirement:
I have a SQL Table in which data gets on adding ( New rows are created )
I want to send that data to SalesForce object .
I don't want to check for any conditions , I just want to push the data to Sf.
Trigger should be : New row created in SQL server table
Action should be copy that to SalesForce to the Mapped fields.
I mean to create a row in SF.
Without checking any conditions ( is it present in sf previously or not .... No need to check )
Just send the data to sf ...
Please reply fast
โ02-10-2022 10:10 AM
https://app.workato.com/recipes/822962-new-updated-row-in-a-table-in-sql-server-will-upsert-opportunity-in-salesforce?community=true
โ02-10-2022 10:12 AM
https://app.workato.com/recipes/897589-sync-sql-server-records-to-sfdc-contacts?community=true
โ02-10-2022 10:18 AM
Hi Viswanathan R
That has a condition .... If contact id is present
and there is no need to update for me, only insert no upsert
That community library recipe will not work
โ02-10-2022 10:25 AM
Instead of Upsert which requires a key, you can use "Create -YourObject- In Salesforce"
