Updating lists on multiple Sharepoint lists
roland-daane
I'm trying to loop through our Sharepoint sites, and update a list in each site.
When use the "add a row to Sharepoint List", I can't parametarize the URL: https://company-name.sharepoint.com/sites/XYZ
So I'll need a custom http action, but I can't seem to get it working.
Does anyone maybe have an example of creating a row in a sharepoint list with a custom http action?
I've tried to take the output of the action, and generate an input Json body, but that doesn't wotk.
"Title": "Test of Location Issue",
"Created_at": "2021-08-03T17:33:34.436000+00:00",
"Synced_at": "2021-08-03T17:33:34.440000+00:00",
"Updated_at": "2021-08-03T17:33:34.438000+00:00",
"Close_version": "",
"Closed_at": "",
"Closed_by": "",
"Created_by": "6KT9RN9BEN8H",
"Opened_at": "2021-08-03T17:33:34.425000+00:00",
"Opened_by": "6KT9RN9BEN8H",
"Updated_by": "6KT9RN9BEN8H",
"Starting_version": "",
"Issue_Description": "",
"Location_Description": "",
"Markup_Metadata": "",
"Tags": "",
"Due_date": "",
"Identifier": "3",
"Status": "open",
"Assigned_to": "YYRFPBLNZFA5",
"Assigned_to_type": "user",
"Answer": "",
"Answered_at": "",
"Answered_by": "",
"Project": "DoES Test Area",
"Issue_ID": "fc219cdd-7ee2-4bfb-8399-03ba1bcbe37a",
"Site name": "025556",
"List": "cf2a2f04-30e4-4c7e-9833-ae84ad89fa41"
soumya-ghosh
Few things come to my mind Roland
1: Check if you can perform the action of adding lists from a http client outside of workato.
2: If getting the list of sites and adding a new site (I am assuming you are trying to create a new site when you say adding to a list ๐Ÿ™‚ ) ....are using same security protocls. Meaning if the get sites is using Basic auth vs creating a site is using something else.
I think if you can validate if it works in something lilke POSTMAN, I would start looking into the request payload to make sure workato is not applying any formatting around it.
Thanks, will give it a try.
We're not creating new sites in this process. That's done for us in another process.
In each site we have a list where I want to append records into. The list name is always the same, the site address differs.
The number of sites will differ, up to about 800 project sites avg.
I have seen this done in Power Automate.
I'll look into Postman. Looks like a great learning environment. Thanks for that tip.
roland-daane
Yes, I've just done so in Power Automate.
Here are 3 images:
1: The flow;
2: The output of the flow; and
3: The result in the Sharepoint list
