05-03-2024 08:57 AM
I have a CDM defined and would like to pass use that as an object input parameter to a recipe function. Is this possible and what's the way to define it so that the object structure is retained within the function? Thanks in advance!
05-03-2024 09:41 AM
Assuming it's JSON, you can paste an example payload into the input parameters of the function recipe and it will parse it out for you.
05-03-2024 09:41 AM
