โ03-11-2025 12:35 PM
In Workato's Connector SDK, upon receiving a response to a request, which key gets processed first, Authorization's refresh_on or, or an Action's retry_on?
Background:
I'm working with an API that, unfortunately, doesn't subscribe to using standardized HTTP codes for their broadly recognized purposes. Expired auth tokens return either 500 or 444, depending on the endpoint, and those same codes are reused across the API for transient/server-side errors.
I've implemented the refresh_on key using string matching:
refresh_on: [401,403,/Token Invalid/,/Invalid Token/]
But I can't do the same for the retry_on keys of various actions, as I don't have every potential error message available to me. Retry_on will have to be set up similar to this:
retry_on: [444, 500]
My worry is that, if the retry_on key of an Action is processed before the refresh_on key of Authorization, 444 or 500 token errors will trigger action retries instead of token refreshes.
Any insight would be helpful, thanks!
โ03-13-2025 01:47 PM
I was able to find a reproducible, non-authentication 5XX error when calling the API I'm working with, so I decided to test this out.
When a 444 is returned with a message body containing 'Invalid Token', the token is refreshed prior to the request being retried, meaning that the refresh_on key is being processed before the retry_on_response key of a given action, regardless of the actual HTTP error code. Logically, this makes sense - the SDK is checking for token errors prior to allowing the Action to retry.
Config:
refresh_on: [401, 403, /Token Invalid/,/Invalid Token/]
retry_on_response: [444, 500...]
Result:
The first call triggers a 444 error due to an expired token. This is handled and the token is refreshed before the action attempts a retry, even though 444 is explicitly specified in the retry_on_response key of the action. The subsequent call triggers a 500, which is then retried at the action level.
โ03-12-2025 03:16 AM
Hi @rlaib,
Here are my thoughts on my understanding retry_on_* and refresh_on
โ03-12-2025 06:41 AM
In my case, the API I'm making calls to is returning 444 and 500 as authentication errors, as well as server and connectivity errors. I can't tell you why they built their API this way, but I have to deal with it as such. I have no control over what error codes they return. When a 444 or 500 is returned as an authentication error, the message body contains the string 'Token Invalid' or 'Invalid Token'. I've added these to the refresh_on key:
When you specifically say that "If an API request fails with an authentication error (like 401 Unauthorized or 403 Forbidden), Workato will first check refresh_on," does this actually mean that Workato will always check refresh_on first, or only checks it first if it's a 401 or 403, even if there are other error codes / strings contained in the refresh_on key?
โ03-12-2025 09:45 PM - edited โ03-12-2025 09:45 PM
Hi @rlaib ,
Yes, `refresh_on` applies only to authentication-related errors, not all cases. If you believe certain error codes specifically indicate an authorization issue that requires a token refresh, it's best to explicitly specify those error codes in the configuration.
I hope answered your queries.
Config:
Result:
