a week ago - last edited Wednesday
[UPDATE 27-Aug-2025] Workato's support team is already looking at this situation. [/UPDATE]
Hello everyone,
After several attempts I'm not able to understand what's going on, hence my question here.
I've built a connector to access Workato Developer API and it has a trigger named "Deployment complete", which uses the list deployments endpoint (GET /api/deployments) to pool for new deployments. According to documentation (FAQ 5), this endpoint only works from DEV and I've created an API client with all permissions to DEV environment.
I've created a recipe and started it in DEV environment. It works pretty well, triggering correctly when there's a new deployment (it polls every 15min).
The problem appeared when I created a second recipe, with the same trigger, same connection config...and it never triggers.
Does anyone have idea why? Can it be some Workato limitation?
I appreciate your time and effort to help me sort this out.
Thanks!
Wednesday
Hmm, yes that makes sense. It does look like it might be a limitation of the Developer API. Please let me know if you happen to find a workaround or solution.
Wednesday
Workato's support team is already looking at this situation and there's a support ticket raised by them.
Friday
Hi @saraiva ,
In workato API endpoint can be liked to only recipe only . If we want to attach another recipe it won't be possible in workato . Again we need to create new API endpoint and link to recipe .Few days back, I have also faced same issue and later known on limitation
Thankyou
