Workato HTTP Trigger unable to fetch file from Azure file share
amit_mohanty88
Hello ,
I am trying to fetch a file from azure file share using get rest API URL which is able to fetch if i put the URL with get request in postman but when trying from HTTP Trigger getting below error .
HTTPS GET URL: https://<<storageaccount>>.file.core.windows.net/<<filesharename>>/<<directory>>/<<filename>>?<<SAS token>>
Error checking for new jobs
Bad input
Summary: Invalid ID column: '' for an event response.
Detail:
Error ID: b2f7c4d4-cae7-4d49-92d0-4f7bbdf026d4
Please note if i am doing a rest call via HTTP Action to this url its able to fetch file contents . Looks like some issue in HTTP Trigger
Please help
Hi @amit_mohanty88,
Can you please share your HTTP Trigger configuration.
From the error it seems the connection is responding with empty data and workato is not able to parse the data.
