Workday Data Feed Processing Failure
jerry-shaver
Total Newbie here building a very simple test recipie to discover how to access data delivered via a Workday Custom report URL. I'm able to retrieve the data stream in Workato and have done so as a JSON file which shows nicely in the output tab of the retreival step. I'm not successful in attempting to select certain records via an IF statement however. Probably because I can't even read each record. If anyone could offer a hint it would be most appreciated. Below is a screenshot of the logic. The IF statement is never satisfied so the logic goes directly via the "NO" path to the stop action.
Actually any pointer toward documentation which deals with Workday integrations would be appreciated.
daniel-seager
Hi Jerry, looking at your recipe I think you want to use the output of the loop (step 3) in the If condition. What you have at the moment will always check the first row in the returned results from step 2.
I hope this helps.
korak666
Hello Jerry,
as a new newby in Workato can you share a screen of the updated recipe that works.
