02-23-2023 01:10 PM
I am trying to use the On-Premises agent to download files to a network share. What is the format of the path that should be entered in the base field when setting up the connection? I have not seen any examples so I was not sure if a UNC path would work. Also, I assume that I need to change the account running the service to one that has access to the share?
02-24-2023 11:54 AM
Hi @jfreund,
Here's more info on setting up connection profiles for on-prem agents: https://docs.workato.com/on-prem/agents/connection/profile.html
There are a lot of different options to choose from, and that doc will outline the steps to set up each.
The account running the service should have access to the share.
02-28-2023 02:30 PM
Thanks, we did change the account that the service was running under and that did give us access to the share.
