Retrieving Jira Issue by Comment
eladasul
Hi all, I am trying to build a recipe that will post new comments from Jira to the appropriate salesforce case... I was wanting to use the trigger for "New/Updated Comment" in Workato, but that does not map to retrieve that actual issue ID/Key, and only refers to the comment itself as you can see documentation below:
https://docs.workato.com/connectors/jira/triggers.html#new-updated-comment-real-time
Ideas anyone?
1 REPLY 1
meghan-legaspi
