Convert list of string to list of numbers
shefali
I/P is ["1","100","50", "4"]
O/P [1,100,50,4]
Hi @shefali,
1๏ธโƒฃ In the 2nd and 3rd images,
2๏ธโƒฃ I have a small curiosity: Why do we need to create two variables with Integer or Number data types to parse a number list?
3๏ธโƒฃ However, when using list functions, it still treats the variable as a list. Shouldn't it actually be recognized as a number instead?
Could you please share a screenshot? I didnโ€™t fully understand your point here.
Looking forward to your insights! ๐Ÿ˜Š
Shivakumar K A
20 REPLIES 20
Hi @shefali,
You can do it using Execute Python Action:
input variable : num_list = list with string values
output variable : int_list = list with integer values
def main(input):
  string_list = input["num_list"]
  int_list = [int(x) for x in string_list]
  return {"int_list": int_list}
Hi Prudvi,
I was wondering if this can be achieved using native formulas/functions, like List or String functions, instead of writing custom Python code?
shefali
Anyone has an idea if this can be done with help of existing functions/formulas in Workato?
Hi @shefali ,
Here is my answer to your question. What would be your next step after receiving the required response?
Please let me know so that I can refine my answers.
