โ02-27-2025 12:49 AM
I/P is ["1","100","50", "4"]
O/P [1,100,50,4]
โ03-02-2025 06:09 AM
Hi @shefali,
1๏ธโฃ In the 2nd and 3rd images,
2๏ธโฃ I have a small curiosity: Why do we need to create two variables with Integer or Number data types to parse a number list?
3๏ธโฃ However, when using list functions, it still treats the variable as a list. Shouldn't it actually be recognized as a number instead?
Could you please share a screenshot? I didnโt fully understand your point here.
Looking forward to your insights! ๐
Shivakumar K A
โ02-27-2025 02:10 AM
Hi @shefali,
You can do it using Execute Python Action:
input variable : num_list = list with string values
output variable : int_list = list with integer values
def main(input):
string_list = input["num_list"]
int_list = [int(x) for x in string_list]
return {"int_list": int_list}
โ02-27-2025 02:39 AM
Hi Prudvi,
I was wondering if this can be achieved using native formulas/functions, like List or String functions, instead of writing custom Python code?
โ02-27-2025 09:52 AM
Anyone has an idea if this can be done with help of existing functions/formulas in Workato?
โ02-27-2025 11:42 PM
Hi @shefali ,
Here is my answer to your question. What would be your next step after receiving the required response?
Please let me know so that I can refine my answers.
