Multiple addresses in NetSuite SOAP
uniaz-alphabold
I need help with attaching multiple address with the customer in NetSuite. I was using list input method, but no matter that I try the addressbook list remains empty for NetSuite Customer Creation. How can I address that? How can I add multiple addresses?
pavan-narayan
Hello @uniaz-alphabold ,
Is it working with only one address ? Also can you share the screenshot here how you are trying to update the same ?
Pavan Srikar N
beatrice-talens
To add multiple addresses in NetSuite, you can update the object in NetSuite by appending more elements to the list or replacing the existing list with a whole new list. You need to specify the object you plan to update and the specific ID of the object to update. At the end of most NetSuite lists, there is an option to select "True" to override/replace all existing list items or "False" to append new list items to the existing list of items.
