โ03-11-2025 08:16 AM
Hey guys,
do somebody know if it is possible to update row values in a table in Power-BI via Workato?
Best regards
Derik ๐
โ03-12-2025 08:09 AM
PowerBI reports and dashboard do not allow updates. you will have to update the data at the source from where PBI is ingesting the data. This is not a Workato limitation, its a PBI constraint.
โ03-11-2025 09:51 AM
Hi @DKWorkatoUser,
You can try Custom or Update Record action by PowerBI app.
โ03-12-2025 12:12 AM
In the Update Record i Only see the two Objects Report and User.
Also in the API Documentaion from Power-Bi i do not see a chance to update Rows.
So the "add rows to a table" action in workato works fine, but I also need something like an "update rows in a table" and a action is not avaible and i did not see something in the documetation to do a custom action.
