04-03-2025 12:32 PM
I am using XML tools by workato and the Transform using XSLT action.
I am converting an XML input to a text output. I do this using the following XSLT element:
<xsl:output method="text" encoding="UTF-8"/>
But workato always seems to add the XML prolog to the output i.e. I get <?xml version="1.0" encoding="UTF-8"?> prefixed to the output.
This works correctly when I use another XSLT testing tool. Is this a bug? Is there a workaround?
Thanks,
Hari
04-03-2025 09:36 PM
Hi @iyerha,
Did you try adding the following attribute to the xml:output omit-xml-declaration="yes".
"<xsl:output method="text" omit-xml-declaration="yes" encoding="UTF-8"/>"
04-04-2025 02:09 PM
Hi Prudvi,
I tried that and it still emits the XML prolog. It appears to be a bug.
Thanks,
04-07-2025 10:51 PM
Hi @iyerha ,
I hope you are doing well,
Here is my understanding on the problem statement:
1. You are basically converting given XML to Text (RAW output) applying XSLT transformation.
2. However, you are getting a response which is including XML header to it (i.e. <?xml version="1.0" encoding="UTF-8"?>)
Here I am adding my insights to the problem statement, let me know if that works for you
1. Please kindly check your XSLT content whether it is applied to your XML.
Here I am adding my input XML, Provided XSLT contents and output.
Input XML
<students>
<student>
<name>John Doe</name>
<grade>A</grade>
</student>
<student>
<name>Jane Smith</name>
<grade>B+</grade>
</student>
</students>
XSLT applied:
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:output method="html" indent="yes"/>
<xsl:template match="/">
<html>
<head>
<title>Student Grades</title>
</head>
<body>
<h2>Student Grade Report</h2>
<table border="1">
<tr>
<th>Name</th>
<th>Grade</th>
</tr>
<xsl:for-each select="students/student">
<tr>
<td><xsl:value-of select="name"/></td>
<td><xsl:value-of select="grade"/></td>
</tr>
</xsl:for-each>
</table>
</body>
</html>
</xsl:template>
</xsl:stylesheet>
Output:
Output: <html>
<head><title>Student Grades</title></head>
<body>
<table border="1">
<tr>
<th>Name</th>
<th>Grade</th>
</tr>
<tr>
<td>John Doe</td>
<td>A</td>
</tr>
<tr>
<td>Jane Smith</td>
<td>B+</td>
</tr>
</table>
</body>
</html>
}Please let me know if the provided output is what you were expecting.
04-08-2025 06:44 AM - edited 04-08-2025 06:47 AM
Hi Shivakumara,
When output is set to html, there is no XML prolog as you have demonstrated. But I am trying to convert to plain text and when I set the output to text, I still get the prolog. Here is my recipe test result:
Response content type: rawdatatxt,
Document: <books>
<book>
<title>Effective Java</title>
<author>Joshua Bloch</author>
<year>2018</year>
</book>
<book>
<title>Clean Code</title>
<author>Robert C. Martin</author>
<year>2008</year>
</book>
</books>,
XSLT: <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:template match="/books">
<xsl:apply-templates select="book"/>
</xsl:template>
<xsl:template match="book">
Title: <xsl:value-of select="title"/><xsl:text> </xsl:text>
Author: <xsl:value-of select="author"/><xsl:text> </xsl:text>
Year: <xsl:value-of select="year"/><xsl:text> </xsl:text>
</xsl:template>
</xsl:stylesheet>
Output: <?xml version="1.0" encoding="UTF-8"?>
Title: Effective Java
Author: Joshua Bloch
Year: 2018
Title: Clean Code
Author: Robert C. Martin
Year: 2008
}However, I agree that using html is a workaround to the problem. But it's odd to use html when the output is not html.
