โ07-09-2024 09:40 AM
Hi I am using the embedded integration gateway in Unqork, I created a api collection with a GET endpoint in there. I use postman to test the request however, the response postman gives is Access to api disallowed and I have given all credentials needed ( if any needed) the gateway does not show any API access key management of any sort. Any solution would be nice!
thanks
โ08-01-2024 05:05 AM
Good day!
After carefully reviewing your concern, further investigation may be necessary. If you want this matter addressed more, we suggest using your active Workato account to submit a ticket through our Support Portal.
Thank you
