- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-11-2022 09:17 PM
Hello automation Pros!
I am working on a recipe that creates users in Active Directory using Windows Server.
I am trying to map Password but I can't find the field to map it.
According to AD Docs the field should be: userPassword
Searching by Passw... in the list of fields to map I found the ones in the image attached.
Anyone one that can help?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-15-2024 12:44 AM - edited 10-15-2024 12:46 AM
Dear, @bcastro .
The error message you're encountering (LDAP: error code 53 - 0000001F: SvcErr: DSID-031A125F, problem 5003 (WILL_NOT_PERFORM)) typically occurs when Active Directory refuses to perform a password change operation. This is often due to how the password is being passed or because of a policy constraint in LDAP/Active Directory.
Common Causes:
- Password Encoding: Active Directory (AD) requires the password to be in a specific format (UTF-16LE encoding) and enclosed in double quotes. This is a common reason for failure if you are passing a simple string.
- LDAP Policies: Your Active Directory might have password policies in place (like password complexity, expiration, or length) that could be causing the issue.
- Permissions: The account you're using to perform the operation might not have the necessary permissions to change or set passwords.
- Secure LDAP (LDAPS): Password operations in AD typically require a secure LDAP connection (LDAPS). If LDAPS is not being used, AD may refuse the operation with the WILL_NOT_PERFORM error.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-11-2022 09:25 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-11-2022 09:42 PM
Just extending CJ's answer...
I think you also need to connect to AD using LDAPS (port 636).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-11-2022 11:38 PM
I was able to find Operation Set User Password in Active Directory. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-31-2022 06:07 PM
Hello Again automation Pros! Continuing with this thread. While using Set Password to User operation I am getting error:
[LDAP: error code 53 - 0000001F: SvcErr: DSID-031A125F, problem 5003 (WILL_NOT_PERFORM), data 0
]; nested exception is javax.naming.OperationNotSupportedException: [LDAP: error code 53 - 0000001F: SvcErr: DSID-031A125F, problem 5003 (WILL_NOT_PERFORM), data 0
I am passing the password as a siple string without encoding it.
Anyone has experienced the same issue? Is it related to the Password Policy set in LDAP? Thanks
