Active Directory- Create User Password
bcastro
Hello automation Pros!
I am working on a recipe that creates users in Active Directory using Windows Server.
I am trying to map Password but I can't find the field to map it.
According to AD Docs the field should be: userPassword
Searching by Passw... in the list of fields to map I found the ones in the image attached.
Anyone one that can help?
ndy
Dear, @bcastro .
The error message you're encountering (LDAP: error code 53 - 0000001F: SvcErr: DSID-031A125F, problem 5003 (WILL_NOT_PERFORM)) typically occurs when Active Directory refuses to perform a password change operation. This is often due to how the password is being passed or because of a policy constraint in LDAP/Active Directory.
Common Causes:
  • Password Encoding: Active Directory (AD) requires the password to be in a specific format (UTF-16LE encoding) and enclosed in double quotes. This is a common reason for failure if you are passing a simple string.
  • LDAP Policies: Your Active Directory might have password policies in place (like password complexity, expiration, or length) that could be causing the issue.
  • Permissions: The account you're using to perform the operation might not have the necessary permissions to change or set passwords.
  • Secure LDAP (LDAPS): Password operations in AD typically require a secure LDAP connection (LDAPS). If LDAPS is not being used, AD may refuse the operation with the WILL_NOT_PERFORM error.
Nguyen Duc Y
8 REPLIES 8
ndy
Dear, @bcastro .
Common Causes:
Nguyen Duc Y
bcastro
Updating my own thread. Set password ONLY works with an SSL Connection.
Hi @bcastro.  Do you by chance have instructions for setting up Active Directory/LDAP SSL? What little information I can find does not provide enough detail.
Thanks in advance.
jeremyo
That was the destination I arrived at as well. It makes sense that security operations require a secure connection.
